CaptSailor
May 09, 2017Explorer
ThomBoles wrote:
It seems to me that you may be better off running the shed and outdoor plug out of your TT that's already plugged in. (pole -> TT -> shed and outdoor plug) Less mess @ the pole and you can control the power going out to there from your existing breaker panel?
Yeah this is the simplest approach for sure, but there are a couple thing about this.
1. The exterior plug on the TT is in a location that will make plugging in a permanent cable less than desirable.
2. I want to run power to my screen room (couple plugs plus a small overhead light, and a plug to my shed. (shed has a solar light).
3. I still want the exterior plug on the TT to be available for temp use when required.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
