SoundGuy
May 07, 2017Explorer
brulaz wrote:
To support the full 16.7A I should probably replace that plug with a NEMA 5-20P, a 20A plug. These only seem available at specialty electrical shops.
Conventional NEMA 20 amp plugs and receptacles are sold at all the big box stores around here I've been to - Home Depot, Rona, Lowes - 'though you're unlikely to find speed box receptacles which you'd normally source from an RV dealer. If load is an issue you might want to replace questionable receptacles with Leviton commercial grade versions that will support their rated full load but require different mounting than speed box versions.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
