SoundGuy
May 08, 2017Explorer
time2roll wrote:
Both 5-15P and 5-20P work fine in 5-20R
Why do you need 5-20P?
SoundGuy wrote:
Exactly. Lug weight in both versions are identical and have the ability to carry the same load, the only difference being the 20 amp has one pin turned 90 degrees to prevent it from being plugged into a 15 amp circuit. Electrically the 20 amp version offers no advantage over the 15 amp.
brulaz wrote:
As stated earlier, I want a 20A rated plug because my inverter can produce 16.7A continuous and has a NEMA 5-20R rated receptacle to deliver this current.
Just because both 15 and 20A plugs will fit in a 5-20R socket does not mean they are electrically equivalent. The prongs may well be the same dimensions and weight, but what about the body of the plug?
You're overthinking this ... Home Depot here in Canada sells this industrial grade Leviton NEMA 5-15 Plug and this commercial grade Leviton NEMA 5-20P Plug, either of which would serve your purpose just fine. :)
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
