Almot
Jul 27, 2016Explorer III
Colo Native wrote:
it is 45A Mppt and the run is under 3'. it said wire is rated 65 amps
65A is the wire ampacity, i.e. the current when cable starts "deteriorating", whatever it means. I assume this is when insulation is getting soft and/or melting away.
45A MPPT doesn't mean much without knowing the array size. This is why I asked about "max post-controller current" - meaning in YOUR particular situation.
Anyway... even if you install 600W array and manage to max your controller up, 45A current in #6 cable @3ft length will result in 0.9% voltage drop, this is within the norm. 45A is within the norm of cable ampacity as well.
I would be (a little) worried about 45A being that close to 65A "point of destruction", but let professional electricians comment from practical experience, I'm not the one.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
