westend
Jul 27, 2016Explorer
N-Trouble wrote:I don't know how you can ignore the calculations made here. The basic physics and math are true for 100 amps or 10 amps and the balanced method is as easy as any other.pianotuna wrote:
Ah but it does matter. The wiring needs to be done so the jars are balanced. See the link posted above and read it.N-Trouble wrote:
12V are wired in parallel so it doesnt really matter which battery you connect +/- to.
In the case of two 12V batteries under realistic loads (not 100A...) the resistance is going to be negligable in real world use to the point you would never perceive a difference in battery performance.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
