Almot
Jul 28, 2016Explorer III
pianotuna wrote:
Hi Almot,
The Tristar units do not let out the magic blue smoke when they over load. They simply clip off the excess. (within reason, of course)
TS MPPT, yes, they will clip the output current with no ill consequences, like any other MPPT.
TS PWM will probably let out the magic blue smoke - like any other PWM when exceeding input current limit.
But I was talking here about the 65A "ampacity" rating of #6 wire mentioned by the OP. Wire specs, not controller specs. MPPT will clip (whatever OP would connect to it), so hypothetical max current (hypothetical max because array size wasn't stated) would be limited by MPPT rating = 45A. Wire #6 can safely handle up to 65A.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
