- pianotunaNomad IIINaio,
That link should be required reading. There are a whole bunch of other topics there that are useful. And there is even a Peukert Calculator to download. - NaioExplorer II
scrubjaysnest wrote:
X 3 reference here: battery wiring applies to solar as well as batteries
Nice link! - Colo_NativeExplorer
Almot wrote:
Colo Native wrote:
One more question do you think 6awg is enough to go from controller to battery, I have a lot left.
What is post-controller max current and what is one-way cable length?
it is 45A Mppt and the run is under 3'. it said wire is rated 65 amps - AlmotExplorer III
What is post-controller max current and what is one-way cable length? - Colo_NativeExplorerThanks Guys after this it all came back to me. One more question do you think 6awg is enough to go from controller to battery, I have a lot left.
- scrubjaysnestExplorerX 3 reference here: battery wiring applies to solar as well as batteries
- pianotunaNomad IIIWiring to the positive on one battery and negative on the other is the correct and balanced way to do this. All other loads and charging should be done the same way.
- downtheroadExplorerMine came factory installed. They wired the positive to one battery (with an inline fuse) and the negative to the other battery.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
