time2roll
May 21, 2015Nomad
As long as you are pulling wire I would go #10 or even #8. Use a step down splice if it will not fit the connector. Fuse for the smallest wire in the loop. 6" #14 will not stop the flow near as much as 20' of same.
You are the relay... unplug when appropriate.
Still may take a 5+ hour drive to get a good charge into a low battery.
Dad probably does some significant driving along with good with conservation.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
