The_Works's avatar
The_Works
Wonderful--Toilet Issues
After having several 5th wheels in our camping life, we decided to try out a motorhome. Our reasons were primarily they are easier to back into a site and maybe drive, I'm questioning this decision. We have had our used 2013 mh for two months and have had no fewer than a dozen issues. Every time we stop at a campground I'm working on something. We full time in it so once we get to a cg for an extended time it has to go into the shop. This morning the toilet overflowed, Good Morning!!, it appears the black tank filled itself to the point water came out of the toilet and of course all over the bathroom floor, hallway and into the kitchen. The black tank vent filled with water and water was pouring off the roof. Its suppose to rain today which hopefully will wash the roof off. We are starting to think the camper is haunted, we've never had this many issues with any of our 5th wheels. Back to the toilet, now the toilet bowel will not hold water, whats going on with this? Do I need to replace the toilet or is the ball valve(I don't know what else to call it) in the toilet need to be replaced? How difficult is it to fix what ever is causing the water to leak out of the toilet? We have cleaned up the camper with fans blowing to try and dry things up. We have used the toilet, sink, kitchen sink and cloths washer and everything seems to be operating fine. We have been on this site for only 2 days so I know neither the gray or black tanks were full, I don't know what happen, everything seems to be working fine and no leaks. The last thing I did with water was last night I filled the fresh water tank to 1/3 level. The cg water pressure is low so we have the onboard water pump on along with the cg water on. Off to fix another mh problem! Thanks for any feedback on the toilet ball valve.
    First of all the guts of a MH versus the 5th wheel are exactly the same! So you can't blame the toilet problem on it being a MH! :B:W:B
    I full time and my MH has NOT seen the inside of a repair shop in 6 years!
    I have ALL my maintenance and repairs done right at my CG site where ever I happen to be. It's called RV Mobile Repair.
    They come to you at your site. They are VERY experienced of all things RV and 99% of the time have the part you need on board or they will have it the very next day. Usually your MH is repaired in one day as you sit back in your lawn chair watching with a cold one.
    Just ask the CG owner who they use for RV Mobile Repair. They will give you the number of the best one in the town you happen to be in. AND they are far less expensive than any RV repair shop. And IMHO far more experienced.
  • Black tanks do NOT fill themselves up... They need some help to fill up.
    Soooo. How long was your tank flusher hooked up?
    I am trying to figure out just what damage may have occured to the toilet because of this.
  • Chris Bryant wrote:
    An over filling toilet will not force liquid out of the roof vent, the only thing that will do that is hooking up a tank flush.
    Methinks OP has been watching re-runs of Robin Williams in "RV":W
    I agree, a pressurized water supply is required to force liquid out of the vent pipe on the roof.
    Better check to make sure the water supply is NOT connected to the rinser.
  • I agree with the others that you accidentally hooked up a hose to the black tank rinser.
    I never leave a hose connected even if the valve is off.
    Please keeps us updated.
  • beemerphile1 wrote:
    Have to agree with the two posts above. Check where the campground water is connected.
    That would also explain your low water pressure.
  • Have to agree with the two posts above. Check where the campground water is connected.
  • Only 2 ways water gets into a black tank is through the toilet or tank flusher.Only way water gets in tank flusher is with a hose connected to it.
  • An over filling toilet will not force liquid out of the roof vent, the only thing that will do that is hooking up a tank flush.
