MEXICOWANDERER's avatar
Dec 25, 2014
WONDERFUL! Aluminum Chinese Wire
They did it. Small items may have tiny single-strand aluminum battery power leads.
25 50 SMD LED plate lamps. The furnished wire extensions with plug have single-strand aluminum wire leads.
STRIP
SCRAPE
Not copper? Avoid using the entension.
Honorable Chinese lack of ethics...
  • Selling CCA as copper is like selling a paper straw for a fuel line. This is definitely fraud, and can seriously hurt/kill.
    It would be great if aluminum alloys getting closer, but AFIAK, they still require one gauge more wire than copper... and one has to take extreme care at connections, or else the wires will corrode and the connection catches fire.
    If aluminum wires did work, houses wouldn't be targets for copper thieves.
  • To say China is pushing the technology envelope on this forum is next to blasphemous!
  • I thought aluminum alloys were actually moving closer to the usability of copper.
    Is it really about cheap or is China pushing the technology forward?
    Besides Americans shop primarily on price so what do you expect?
    Please post when the item fails due to the aluminum wire.
  • 3_tons's avatar
    3_tons
    Explorer III
    Could it be that they are tinned copper to help resist marine corrosion??
  • The "10 gauge" MC4 pigtails on my 230w solar panel turned out to be aluminum wire. I found out when I cut the ends off to connect them to some #8 wire I have.
    I wonder if the 25 ft extensions you can get for those solar panel MC4s are also aluminum. If so, you need to "adjust" your voltage drop calculations to al vs cu.
  • CKNSLS wrote:
    I am sure they said "Made in China" somewhere on the package BEFORE you purchased them.......
    Caution---CHINA bashing thread ahead!!!
    You are absolutely correct...
    My error...
    Shudda opted for the ones manufactured in Furgueson
  • I am sure they said "Made in China" somewhere on the package BEFORE you purchased them.......
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 21, 2025
