We used 171 amp hours last night with the PC, fans for us on and the hot weather causing a longer run cycle on the fridge etc..
We were at 70.9 percent SOC this morning
101°F is today's predicted high, yesterday was 97°
It took three hours for the charging amps to drop from 62.3 to 30
So I could power the A/C from the 3k champion inverter generator
Current charge rate 27.1 amps , SOC 94.1 percent, 566 amp hours
The LP onan has a melted wiring harness problem I need to fix
Caused by hot diesel exhaust after losing the tail pipe extension
I had new tail pipe installed while at the shop for the injection pump
High temp hit 102°
