How do you get the batts to "true full" when there is always a load on them while you do the recharge?
I thought it would be necessary to do a split bank and get some batts full while the others did the work, and then swap around so all the batts got their doses of top charging. However, since the charger does the loads first and the batts get what is left over, does that mean you can get the batts full anyway, even with a load running?
But then how can you tell when you are "done" with amps flowing to the loads too?
Love having the flexibility of the PowerMax Adjustable for customizing the charging profile for any particular battery's specification. :)
