Vacationer04
Sep 29, 2019Explorer II
Workhorse 8.1 GM exhaust gasket replacement
My 2004 HR 36' MH (Workhorse - 8.1L GM) has a bad gasket between the exhaust manifold and the cylinder head only on the passenger. It does not at present have any broken studs or manifold but they are rusty enough that I do not have any confidence that I can get them off intact myself.
I have called about every place that I can locate that does truck service but I get told that it's too big, too old, or it's a Workhorse with the reputation of broken studs and manifolds. Has anybody used a place near St. Louis for this kind of problem? I had planned to acquire an Ultra Tuning ECM but after talking with them and giving them the scanner data I discovered an exhaust leak that was not audible until checking fuel pressure with the doghouse open. I was advised that the ECM would not be an improvement to my low performance until the repair causing it to run lean was corrected.
Help! I'm at my wit's end with frustration, unable to get anybody to consider my dilemma. I believe an acetylene torch would break the rust but I have no access to one.
