mlts22's avatar
mlts22
Worth seafoaming a Yammy 3000 iSE before replacing carb?
Due to real life events (layoffs, friends and relatives in ICU) , I have not had time last year to do the usual upkeep on things as I should normally.
Pulled out the generator, starts at full choke after a number of pulls, and surges at no load. Add 750 watts... still surges. Add 1500 watts, smooths out, and after 2-3 hours, when the load is removed, the generator works fine (econ switch on or off.)
Had a friend of mine rebuild the carburetor. Not sure how thorough a job he did, though. Since I started a new job, and in the process of cleaning a lot of stuff out, (not to mention a renaissance faire), I don't have the time and table space to rebuild the thing myself, which is why I'd just buy a replacement, Onan-style, rather than try a rebuild.
So, before I pay the three C-notes to buy a new carb assembly, is it worth tossing four ounces of Seafoam in the tank with a gallon of gas, and letting it run, or would that just waste fuel?
  • mlts22 wrote:
    it is wise to have the shop get the generator starting on the first pull (or twist of the starter)... then go, item by item, down Yamaha's checklist.
    Yes, correct.
    My point is that it is NOT wise to do it the other way around; that is, give them a list of the things you want serviced without mentioning the basic problem.
    You might be surprised at how many people do that, often from advice garnered in places like this, and then go back to pick it up only to say "But it is still hard to start and surges".....with a bill for several hundred dollars only to find something like a cracked head or that it needs a valve job or rings and is not worth fixing. But you still have a bill for the service that you requested.
  • Sam Spade wrote:
    John&Joey wrote:
    I was actually hoping mlts22 would do a follow up.
    The odds of him making a reply would have been MUCH higher if you would have addressed the question TO HIM.....or quoted his post. ;)
    Appears not to be the case.
  • I do appreciate the advice. If the repair place can't get if fixed, why throw good money after bad?
    If the SeaFoam treatment doesn't do the job, I'm probably going to recommend fuel additives be used stabilizers, to prevent varnish, as opposed to something which can actually do something about it. For a real cure, it takes pulling the carb, soaking it in solvent, and blasting open the jets with compressed air.
    Very often that is not the case.
    IF you use a real cleaner with real proven solvents in it.....instead of a product designed to be a stabilizer and just happens to have mild cleaning ability.
    Berrymans B12 Chemtool is a good cleaner. Seafoam is not.
    You must do what you think is right but tearing the carb apart often is NOT required if you just use a good cleaner.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
