Sam_Spade
Jan 29, 2016Explorer
mlts22 wrote:
For a real cure, it takes pulling the carb, soaking it in solvent, and blasting open the jets with compressed air.
Very often that is not the case.
IF you use a real cleaner with real proven solvents in it.....instead of a product designed to be a stabilizer and just happens to have mild cleaning ability.
Berrymans B12 Chemtool is a good cleaner. Seafoam is not.
You must do what you think is right but tearing the carb apart often is NOT required if you just use a good cleaner.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
