Question is that there are three "OUT" ports on the valve I am looking to purchase . Can any one of the three ports be used while blocking off the other two ??? thanks
Most versions will not have all of the outlets (or inlets) drilled and tapped, only the ones called for in the application, and maybe an 1/8" test port.
