msiminoff
Nov 14, 2014Explorer II
I also have a ProSine 2.0 and love it… but it has given me some problems in the past. The issue I had turned out to be that one of the circuit boards was disconnecting from it's edge connectors. I machined-up a few c-clips from ABS to hold the connectors together and it has been trouble free ever since. It's worth taking a look to see if you are having a similar problem.
If I ever need to replace the ProSine, I'll go with the Magnum Hybrid (MSH3012M)… It's worth taking a look to see if one of these will fit in the spot where your ProSine is mounted.
Hope this helps.
Cheers,
-Mark
Hope this helps.
Cheers,
-Mark
