wa8yxm
Nov 27, 2018Explorer III
There is a man at Quartsite who fixes 'em. Next time I get there (Was hoping this year but not looking good since the slide out motor/transmission is shot) I will hand him mine....
For the time I went with a FREEDOM 2000 XC Less than 1,000 Remote included and I did the install myself. Have the following observations
Where as the Prosine had toggle switches that disabled the inverter. or charger this one does not. However there is a way (I use a different charger so I disabled it) and I can turn it on and off via the remote.. just more hoops.
Second the connections were..Much more of a pain. the "Quick connectors" they provide did not like my older 10ga wires. I had to make them connect.
After that I got 'er hooked up but unlike the Prosine the ON/OFF is quite different. A single button and NO indication if the inverter is in 'Standby' or "off" modes.
Last time I moved (This was not a problem) I had a different 12 volt issue that sucked battery down for just an instant. Low enough my LED lights flicked.. The inverter SHUT OFF. I had to re-activate it when next I noticed.
But otherwie it is working well
I miss some of the Prosine's features though.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
