MrWizard
Nov 27, 2018Moderator
DavesRVs wrote:KJINTF wrote:
Hi Rainbird
I agree those Prosine2.0 units when working are nice units
Got one in pieces here on the shop bench with the dreaded error code 0258...
Right now I believe there are defective caps seeing that they used the cheapest ones they could source at the time in the early 2000's.
Hi there..
I can seem to find the Prosine numeric codes online anywhere. I have a Prosine 2.0 with "Dreaded Error Code 0258"...
How do I fix that? (I am an electrical Engineer, so I know just enough to be dangerous :-)
Thanks
This topic is 4 Years old
i think it would have been a better idea to start a new one
Prosine is very bad about NOT doing repairs
if its in warranty they replace it,
if its out of warranty, tough luck, unless you find a guy that specializes in them
NO published info from them
the only thing i can recommend is the use of a 'component' wave form tracer/comparator, they look like an oscilloscope but are not
a bad FET , CHIP, diode etc.. will show a different waveform from a know good part of the same thing
