Canadian_Rainbi's avatar
Nov 13, 2014
Xantrex Prosine 2.0 Inverter/charger died! :(
The Subject pretty much says it all.
No throughput, immediately trips shorepower breaker, doesn't trip generator breaker, but does not pass the AC through to the coach.
Inverter function seems to work fine.
Returned from Xantrex and Not repairable, no parts available. The 12 Volt version is no longer made.
I see a few offered on Amazon.com and ebay.
I can find no other 2 KW pure sinewave inverters that will fit the space. The storage forward of the battery compartment (to the right in the photo) in in a slide out which would make wiring difficult if not hazardous.
Thoughts?
  • I recommend GoPower 2kW mounted just below or to the bottom of that shelf.
    Get a separate converter to charge batteries.
