Canadian_Rainbi
Jan 14, 2016Explorer
2oldman wrote:Canadian Rainbirds wrote:You have an xfer switch in addition to the Pro's?
The main transfer switch is ahead of the Prosine 2.0, from the shore power and the generator.
Yes
Shore power and generator to Transfer Switch.
Transfer switch output: L1 through the Xantrex which has an internal transfer switch for feed through and invert.
L2 bypasses the Xantrex.
I'm not sure where the Intellitec fits in.
"Half" the circuits are always fed via L1. For instance If the Xantrex cuts the power because it is out of parameters we still have voltage at the galley and lounge plugs which may be too high or too low. When we are running from the inverter alone these plugs are NOT energised. When everything is working as it should we have power to all circuits when on shore power or generator.
