pianotuna
Jan 15, 2016Nomad III
I'm sorry the inverter is now in 'rest in peace' mode.
I'd be tempted to upgrade the battery bank to LI, add some more solar and go with a residential fridge.
For the inverter to last it needs to not be 'pushed' to the edge. If you have a 50 amp service I'd be tempted to move to a 24 volt battery bank and one of the 4000 watt hybrid units from Magnum or Victron.
The other route is to get separate components, i.e. a stand alone inverter and a stand alone converter. 2oldman is having great results from his switch to 48 volts and can now run everything including the roof air easily. His route was separate components.
I do hate transfer switches whether they are internal or external. Usually when one reads the 'fine print' it says to not switch under load.
