liborko
Aug 11, 2013Explorer
-do you have a temperature sensor mounted to the battery post?
-are your batteries OK(shorted cell)?
-are your batteries dry low on electrolyte?
My Prosine 2.0 is mounted under the dinnete seat next to four 6V gel cell batteries and I installed fresh air duct to the Prosine for better cooling and 3.0" exhaust duct for good air circulation. I programmed max charging current at 90A and it will start charging with 90A even if the batteries are only about 25% down. The maximum batteries temperature I ever saw was 34* Celsius. It is working flawlessly since around 2006.
The Prosine fan seems to run more often when batteries are fully charged. The fan does not run when Prosine is working hard. Semiconductors run cooler when fully on.
