ramblinwreck's avatar
ramblinwreck
Xantrex prosine 2000 over temp
My prosine 2000 is giving me a fault code that temp 1 is too high. If I clear the fault or if I power the unit off and turn it back on, it will start and charge the house batteries at a high current (about 75-80 amps) for about 3-5 minutes. Then I can hear a relay click and the overtemp alarm comes in again and the charge shuts off.
This was attempted during a warm august day but I've used the prosine year around in much warmer temperatures.
I put my hand on the xantrex box itself and it is warm but I've noticed it warmer.
Two questions:
Is this xantrex a goner? ie should I replace it? I've read that xantrex doesn't share wiring diagrams making troubleshooting a problem.
Second question on researching a replacement inverter/charger is that all of them take a power derate when operated above temps about 25C (77F). Where do you keep your inverter? Mine is located in a basement compartment in a Class A motorhome and I'm guessing the only time it sees less than 77F is on a cold winter day.
  • Xantrex support is probably worth a shot. It's hard to say what could be causing this.
  • It's original equipment so it's 7 years old.
    Is the fan accessible and replaceable? Is it like a computer fan that I can replace? (can't recall but I think it was running.)
    Does anyone locate their inverter charger inside the coach?
  • I am interested in reading the responses. I have a similar problem when running my Heart 458 on the generator. It goes over temp and stops the charging. The batteries are not hot, the inverter/charger is not warm, and it makes no difference if I disconnect the temp sensor.
  • How old is it? As I recall Xantrex warranty is 5 years.
