pianotuna
Feb 26, 2014Nomad III
Xantrex SW3000
Hi Folks, Well Xantrex has an inverter charger with temperature compensation on the battery. Worth considering I think. Unit weighs 73 pounds. sw inverter/charger 3000 watts Opinions?
Chris Bryant wrote:BoonHauler wrote:
Whoa, the Xantrex has a 3 amp standby, that's a lot more than the Magnum!
The Magnum is rated at 30 watts, which is ~2.4 amps, so not a lot more, plus the Magnum is termed "typical", which is code speak for "could be more".
I've had no problems getting all but the RS series repaired at my closest Xantrex service center. They are pretty proprietary with their info though.
