Hi Folks, Well Xantrex has an inverter charger with temperature compensation on the battery. Worth considering I think. Unit weighs 73 pounds. sw inverter/charger 3000 watts Opinions?
I'm curious to see if there is a difference in readings between a "standard" ammeter and a "true RMS" ammeter. Magnum does specify the charger is "high frequency". It may do some sort of pulse charging which might confuse the readings, or perhaps the pulse current is 125A but the time average is less, as shown by the Trimetric?
