agesilaus's avatar
agesilaus
Explorer III
Apr 13, 2020
Yamaha vs Honda 3K
OK I'm thinking about upgrading my current generator to either a Honda or Yamaha 3K. And want to use an extended run tank. I understand these larger units do not have a fuel pump so use the vacuum pull system for extended run.
The much greater weights are an issue, but these are supposed to be much quieter that my current gen and I may be able to run one from the platform on back of my TT.
I have an old Honda 2K and it has been nothing but trouble, went to the shop for a carb replacement with not much improvement. So I am slightly leery of Hondas. But understand I may just have a lemon.
The other option is 2 2K units ganged together but then you have to feed two tanks. I wonder if you could feed both from a common external tank.
Anyway whatever comments you have will be helpful. Does the Yamaha have an RV plug?
