campigloo wrote:
Hi y’all
I’m still shopping batteries for my solar setup. I want agms and am leaning toward 6v gc instead of 12v deep cycle. Does that sound reasonable? I know this is vague but I’m trying to keep it simple.
Thanks
Short answer. Good plan
Longer answer
If you can get 12 volt DEEP CYCLE batteries (IE: GC-12's) then 100 amp hours is 100 amp hours.. or to be more precise 100 amp hours is 50 amp hours since you can safely use only half the power.
But most 12 volt batteries are MARINE/deep cycle and should not be run down to 50% so 100 amp horus is 25 amp hours on a MARINE/deep cycle.
Now the next point: Because golf cars use GOLF CAR (GC) batteries. golf courses from here to there and back again buy 'em by the pallet load.. often 2 or 3 pallets.. this makes them the single most produced battery. the 6V lines at the battery factory basically run year round without re-tooling save for updates... 12 volt lines get re-tooled for different sizes often... Re-tooling for different sizes is costly and adds to the price per unit power storage of the battery.. Making the GC-2 the best BANG (Totall watts stored) for your buck (For the cost).
So the long answer is "Good plan". as well
NOTE you can get 12 volt deep cycle. and some very very large ones as well but the 6V GC-2 still is the best bang for the buck.
