Sam_Spade
Sep 08, 2019Explorer
Chris Bryant wrote:
Those carbs are near impossible to clean- just replace it.
Yes BUT.........
SeaFoam is really NOT a good cleaner.
And if you put those two cans into a gas supply that runs ONLY the generator, then that is WAY too much and might actually be causing the problem.
If you can get a fresh supply of gas to the gen, I suggest adding two ounces per gallon of Berryman's B12 Chemtool to the gas and then run it a few times.
Even that didn't fix mine and the Cummins/Onan dealer recommended the above.....and it wasn't as expensive as I had guessed.
