dougrainer
Sep 08, 2019Nomad
You can pull the carb and CLEAN it. Not rebuild. Remove the fuel bowl and unscrew the jet assbly. You have 16 micro holes in it and cleaners will not remove the debris. Just use carb cleaner and compressed air. You have nothing to lose. If that does not work then replace the carb. Doug
