bounder39zman
Sep 09, 2019Explorer II
I have attempted to clean/rebuild dozens of these carbs, with mixed results. some work great...some never quite run right. But just in case you missed this, there is a soft metal seal ring INSIDE the bowl,
that seals the bowl to the venturi tube. It is easily lost when disassembling bowl from carb. it will run like **** without it.
It will overfuel badly. Otherwise, OP's suggestions to replace the carb probably only thing to do at this point.
