BFL13's avatar
BFL13
Explorer II
May 20, 2014
Yet Another PWM vs MPPT Comparison Test
I was able to run a couple tests with blue sky at same time of year and location as my test from two years ago (flat, tilted, tracking results one) that :
A. compares PWM with MPPT, and
B. compares MPPT at 14.0v with MPPT at 12.2v (battery)
First test:
0900 battery 13.3v-- 130w panel and PWM at 7.3a (same as two years ago at 0900) Scaling this to 230, should be 7.3 x 230/130 = 12.9a
The actual 230w MPPT was 13.1a and 176w
Second set with sun higher at 1000.
Test one-- battery 14.0v
130w panel rated Isc is 8.2a but the IV curve drops this at mid-13s on up, Got actual Isc as 8.21 but with the 14.0v battery got 7.8a, scaled up to 230 should be 13.8a
MPPT was 13.59. 230w Panel rated Isc is 8.3a, 37Voc. Got 8.26/34.7
Test two-- a few minutes later with loads running and battery voltage now down to 12.2 holding there.
PWM 8.2a-- would be 14.5a at 230. 230 panel now at Isc 8.42 and 34.7Voc.
Still at 189w with 12.2v and 15.48a.
So as shown in the previous set of comparisons last month, the MPPT "performance" is all about battery voltage as to how many amps you get.
Summarizing the above on the same 189w (of 230w) you can have
13.59a with 14.0v, or
15.48a with 12.2v.
At high noon MPPT should do better than here at 1000 but some clouds coming in, not sure will get a noon reading. Will edit that in if available.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
