McKenziek
Jun 24, 2013Explorer
Almot wrote:McKenziek wrote:
I wont run the Micro on inverter. I dont have the unit nearby where I can see the load rating
+2,000W inverter will never be "nearby" - it has to be very close to the battery. Forget that voltage display on the inverter. For watching loads people use standalone watt-meters or battery monitor like Trimetric.
Agreed with other posters - 120V fridge is what makes generator-free life impossible. It draws less current than MW but for much longer time, over 24 hours it will consume more than all your other items. MW is bad only because it draws high current and therefore requires costly inverter.
I meant that the Motorhome is not at home so I cant check the power rating on the fridge
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
