Golden_HVAC
Jun 27, 2013Explorer
McKenziek wrote:
Lot of good replies and much appreciated. My goal is to be able to run my 18 cu ft residential refer without having to use my propane generator and occasional use of the microwave. I have 2 Trojan T105's with plans to get two more. I will take a look at Pianotuna's load spreadsheet, that should do the trick.
That large of a load will take a lot of solar panels.
You can start out with 4 each in the 100 - 175 watt range. Larger than 175 watts, it is really not something that you can locate on a RV roof, and still be able to pass by it when cleaning the roof, or making repairs.
You really do want it tiltable, in case you need to tighten the wire connections, or repair the roof.
You really need to have it about 1" above the roof, so cooling air can get under it. Solar panels produce much less power when hot.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
