NinerBikes
Dec 10, 2014Explorer
cdlaine wrote:
Wow... the Ford crew here has me officially jealous with these MPG numbers
being posted. My gasser typical... unloaded (around town) 10.5-11 MPG. Loaded
(flatlands 7.5-8 MPG).
Best I have ever tallied...
15 MPG (unloaded) on a long haul , flatlands, with cruise control at 55 mph.
Hats off to your diesel Ford numbers.
BTW... what does "taller gears" mean ???
Charles
A vehicle geared "tall" has gearing such that the motor loafs and turns less rpms at any given speed, while in overdrive. So if you are doing 60 mph, your motor turns 1800 rpms, instead of 2200 rpms. Important when driving a diesel as diesel motors, because of the way diesel fuel burns, are optimized for a sweet spot for maximum fuel efficiency of around 1500 rpm (think Cummins inline 6) in bigger motors, to 1900 in smaller 2 liter diesel motors (think Volkswagen SUV's and sedans, where each cylinder is .5L in displacement.)
The flame front of diesel fuel ignition moves very slow, while making power, such that higher rpms defeats getting a complete full burn of the fuel, the piston falls away on the ignition stroke faster than the fuel can burn, above a certain, usually max torque rpm figure. So you want to be running that motor as close to that max torque rpm, regardless of load, at almost all times. Having an 8 speed gearbox, or a 12 speed, allows this to occur more frequently at all driving speeds. With enough gears in a gear box, being geared tall or short should be a non issue, regardless of load you are towing, the transmission will select a lower gear to run if need be, for the amount of weight towed.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 09, 2026
