Yes, it will do better than a 15amp but realistically limited to around 2.8kw with the 80% rule. With an 80kwh battery bank, you are looking at around a full 24hr to recharge. This assumes you can dial in the charging rate and you aren't running anything else in the rv. If you are running the aircon, that could cut the charge rate by half.
Also, during peak summer season many campgrounds won't be able to handle many rigs maxing out their pedestals...they often struggle with aircon units which don't run 100% of the time.
Finally there is the cost to the park. Pricing is based on typical usage...what you propose is likely 3 to 5 times the power consumption of an equivalent rv...you should be paying for that. 80kwh at 0.25...is $20.
Don't be the bad apple that ruins it for others.
