cummins2014 wrote:
FishOnOne wrote:
cummins2014 wrote:
4x4ord wrote:
There isn’t a hill I’ve been on that I would be afraid to descend pulling a 16000 lb rv with the 7.3 gasser. Low gear and 6000 rpm is a lot of engine braking.
You are a brave lad !!! Can't argue the fact of what a 7.3 gasser will ,or will not do , but I towed a fairly heavy fifth wheel many years with a 7.3 Powerstroke , no EB . Had a few white knuckle experiences coming of some of the hills in Utah, Idaho ,and Montana . Yes learned pretty quickly on how to come down some of those long grades . One example is the one coming from Ennis,MT to Virginia City , MT. It has the runaway ramp if needed .
There's no comparison of the 7.3 Gas with a throttle body, and transmission grade braking compared to a 7.3PSD that has absolutely no grade braking functions.
Bottom line...I'll take a 7.3 Gas over a 7.3PSD anyday for all towing applications.
I will take a 6.7 Cummins over both of them for all tow applications .
So what are your impressions on driving a 7.3 gas truck?
