RobertRyan
Feb 21, 2021Explorer
rjstractor wrote:RobertRyan wrote:RoyJ wrote:
The Fuso, a lowly 161 hp. But, it's meant for efficiency in commercial use, not high performance recreation.
Recreation demands "fun factor". Look at boats - an offshore sports fisher can run 1500 hp, all to catch 3 tunas. A commercial trawler with a 25,000 lbs salmon hold may run a 90hp Perkins.
That Fuso is only a 3 Litre Diesel, these are 5.2 Diesels
Fuso can go to 480hp, 2300lb ft of torque
The one I drove was a 3.9 liter, 140 hp IIRC. (this was about 15 years ago) It could not maintain 60 mph on a 6% grade empty. The 5.2L Isuzus have much more power, but still only half what a new HD diesel pickup has. They might haul 5K and tow 9K on the flat at 60 mph, but on a grade it's 35 mph, right lane, flashers on. I see it all the time with the landscape company trucks. Many of them run a crewcab with a 12' landscape body towing a large tandem axle enclosed trailer so they are probably at about the aforementioned weights. And they are miserably slow on the hills.
what you talking about was pretty underpowered, again it is a light Truck. You can have a 10,000lb payload same 8000lb/ 9000lb Caravan 4x4 Truck. Depends on the truck you use. I doubt anyone here would use a Japanese Tractor truck, but you even get them cheaply enough 2nd hand.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 01, 2026
