JJBIRISH
Jun 02, 2013Explorer
I haven’t found a single recommendation, or suggestion that any of the Vanco tire series including the Vanco 2 or Vanco camper tire should be used for trailers…
Most rate them as heavy duty passenger tires especially designed for van use…
Snip:
The growing demand for short-distance transport of passengers and goods also leads to increased requirements so that the performance of modern day vans nears that of passenger cars.
Snip:
The concept of the VancoTM Camper is to use long well-proven Vanco technique, optimize its performance for distinguished motorcaravan requirements and thus cater to the needs of this specific target use.
Snip:
The Continental Vanco Camper tyres are part of Continental’s Vanco tyre range that comprises tyres exclusively for vans.
Snip:
The 'C' that follows the rim-diameter figure (eg. R15C) originally meant 'Camionette' (French for van or small truck). In English the 'C' is translated to 'Commercial' as an abbreviation for 'Light COMMERCIAL Vehicle'. the 'C' suffix indicates that a tyre is designed to be suitable for a commercial light truck, transporter or van. The 'C' letter has nothing to do with the Ply Rating system, nor the number of plies used in a tyre's construction.
Snip:
Also the CP rating deals only with small van MH tires air pressure ratings and only deal with srw trucks or vans mandating and using the full sidewall air pressures only…
They seem to be a cut above extra load P rated tires but are not LT tires…
Maybe a dream come true for lawyers and insurance companies looking to pass on liability, from a accident…
Nor does it say anything about for trailer use
Most of them are built to European sizes specs and standards that might or might not be different from ours…
This to might just disqualify many of them… “if available in an appropriate size, load range and speed rating to match the existing O.E. tires’ performance category and specifications."
Snip:
Snip:
Snip:
Snip:
Snip:
SprinklerMan wrote:
This is dirrectly off the website , doesnt say a thing about not for trailer .
LT stands for light truck or light trailer . I run these tires on my trailer , they are great .
