falconbrother
Dec 02, 2017Explorer II
I just ordered a regulator from rockauto.com and it works perfect. It's not an OEM part but, it works perfect. On GM you remove a couple of screws and the door liner slides up and off. Then pull back the plastic moisture barrier and the rest is easy. Tape the window up and the regulator assembly comes out with the removal of a couple of nuts and bolts.
44,056 PostsLatest Activity: Nov 19, 2013
