rhagfo
Dec 26, 2014Explorer III
FishOnOne wrote:rhagfo wrote:
Well, sure seems like a lot of work to drain the water/fuel separator! :S
The one on my Cummins is easily reached under the hood and is a simple lever, no tools required. :)
This is something you want to do as soon as the warning light comes on, needs to be easy and quick to do.
This RAM cummins has even a better idea... Stick the water/fuel separator near the exhaust so you can either burn your hand/arm or catch your cummins on fire when you have to drain your water. :S
Link
It appears the 1st filter is a primary, the Cummins filter water separator is still on the engine. The 1st is over the drive line, not the tail pipe although it is not too far away.
