FishOnOne
Dec 26, 2014Nomad
rhagfo wrote:Hank85713 wrote:
on mine the light came on while traveling and I needed to drive another 100 miles before I could get at it. amount of water was less than 1/8 teaspoon if that much.
I have read that there is not much in the system when the light illuminates, I have only drained 1 time since owning the truck and I bought it new in 04. Filters are changed regularly, but I dont live in a wet/humid area area either.
Fish the point is that draining the water separator should be easy and quick! It is easy and quick on a Cummins, no tools required! To have to craw under the truck to drain the water separator is poor design.
I would never drive 100 miles with the water in fuel light on.
As usual your point was useless to the OP.... In addition on a current RAM you have to crawl under the truck to drain the water/fuel separator too. Sorry but that's just how it is. In the video did you see the description on the filter box for the filter that went under the truck say "fuel/water separator"? Plus the tall tell sign it's a water separator filter is the electrical wire/plug that connects to the bottom is this filter. The filter under the hood has a drain to remove the fuel from the filter housing, and I noticed the guy had to cut is plastic fender well to get access to this filter.
