Reddog1
Feb 08, 2016Explorer II
covered wagon wrote:Where did I say what I put in red in your post? Have I misspoke, or maybe you misread? If you misread, ....Reddog1 wrote:
covered wagon, could be you are putting too much into this. I kinda wonder how much research/experience you have on this subject as it pertains to the Dodge/Cummins trucks. Theory and perfection goes a long way, but it is by no means absolute.
Wayne
Wayne, I have done enough research to know what I'm talking about. Big primary filters should do and are designed to do all of the work pertaining to problems discussed here. I don't understand how you could think putting a filter in the tank is going to do anyone any good. I say this because the primary filter has to go on the suction side of the pump. I get mad when I hear people being a victim to these improperly set up trucks.
All boils down to whether you want a properly set up serviceable truck. It's not hard to see and I've modified mine even further than said here.
Wayne, is yours a 12 or 24 valve?
Mine are both 12 or 24 valve, a 1996 (12 valve) and a 2004 (24 valve). Keep in mind, the 24 valve has at least two different fuel systems (1998.5 through 2002, 2003 and up) as I understand, with unique requirements/demands for each.
Wayne
