smoke20's avatar
smoke20
07 ford cab clearance
with my tc on my 99 ford i had no issues with the cab over clearance. but on my 07 crew cab it wont clear. on our first trip i jus threw a few 2x10's across the bed floor and strapped her down and rolled out.
i was thinking about using two 2x6 boards as cross beams with a valley cut in them for for the height and centering of the TC. then fill the gaps with pink foam board. also figure i would cut the 2x6's long enough to fit into the factory notches in the bed for boards
jus wanna see what you other ford guys have done. i know its a common problem with ford cabs.
here is a drawing i made to help visualize what i'm tryin to say
  • One thing you might want to consider is the foam board will compress while the 2X6's won't thus leaving two relatively narrow strips of contact especially during travel.
