MitchF150 wrote:
I've got a 13 Max Tow with 3.73 gears and #1920 payload, but I'll bet it's the same #4050 rear gross axle rating as your 13 with 3.55's...
If you are over your rear axle rating now with the #800 TW on the trailer, then what's the rear GAWR of the 2017?
If it's the same #4050 rear GAWR, then the payload really means nothing.
But, that's all up to you to decide which rating you go over, right?
Good luck!
Mitch
The rear GAWR on my '13 w/3.55 is 3850. I have been -50 and +70 the two times I weighed it. Both times I could have moved some stuff from the truck to the camper. I'll learn to do that one of these days. I think the 2017 specs are the same as '15, 3800 rear GAWR. But the truck is lighter, so there should be more load carrying capacity. I haven't found anything different from that.
