Hi, Any body have a 3500 std cab RAM DRW with an newer 1150 Arctic fox? How does it handle? My 02 990 Dry bath is great on it. Just ordered 2021 1150 dry bath. Thank you, Andy
With that much weight, you will probably need to fine tune the rear suspension. I eneded up removing the secondary overloads, they made the ride unbearably ruff. Then I added air bags, and a couple more of the longer leafs in the spring pack. That worked out perfect with the 1150.
