JumboJet's avatar
JumboJet
1157 LED Replacement Bulbs
I purchased 4 Pilot Automotive LED 1157 replacement bulbs (IL-1157W-15} to install on my 2000 model motor home. The tail light cluster is a Bargman very similar to what is in use on older Lance truck campers. I am sharing my motor home results just in case someone has $$ burning a hole in their pocket and wish to replace their incandescent 1157 bulbs with LED.
The MAJOR problem encountered was when the turn signal was used, all the side marker, clearance, parking, and tail lights would dimly blink.
When this issue would be encountered with an incandescent bulb, you would begin searching for a bad ground.
I checked all the grounds and found them to be good.
My theory (proven to be true) was since the turn signal and tail light use the same LEDs, the stronger current allowed (regulated via internal resistors) during a turn signal operation was back feeding the tail light wire on the motor home, thus causing all connected bulbs to become energized.
Solution: $5.00 of parts from Radio Shack - two #6A2-TPMSCT diodes and two #274-656 terminal blocks.
The diodes are placed inline of the tail light wire just before the tail light/stop light fixture. One on each side of the motor home.
The LED light problem was fixed!
Video - Blinking
