dodge guy wrote:
So are we to expect to run back and forth to the cement place to get a load? That would barely be enough for 10X10 pad! Seems to me this is for mixing bagged concrete on site. I rented a smaller one to do my Hit Tub pad. Worked perfect. And I used my 01 Explorer.
I fail to stand under this question. This trailer looks like a good way to avoid short load charges. IMHO it would be even better if you could pick up the sand, rock, and cement loaded in the hopper, add water and mix when get to site. Not likely to happen, because once the water is in the owner knows the renter will hurry to unload it.
