Family-of-five's avatar
Aug 25, 2020
12 volt frige
Just got our new highland ridge bunkhouse camper!! Got to learn everything about it now. It has a 12 volt frige and I never had one before. If I am correct it is 12 all the time even when plugged into shore power. anyone else have one? Do you like it?
  • old idaho guy wrote:
    We have a 2020 Coachmen Pursuit xps that has a 12 compressor refrigerator. No propane. Recommend some solar panels. The refrigerator is 12 cubic feet and works very well. We only camped in it once and had to run the generator for AC so I am not sure if the 200 watt solar panels can keep up.
    Run gen for AC. On MH this is another that baffles me. APU on a truck uses a small engine to drive a AC compressor, and a alternator
  • midnightsadie wrote:
    question if its only 12v ?it would run a battery dead real quick. find a friend and have then do a walk threw on your rv,show you where things are and what they do,have fun.
    Sjm9911 wrote:
    Look for a controll panel on the fridge. It might be outside under the fridge vents. Or on the front. I've really never seen a fridge that was just 12 volts in a camper. As stated it will drin the battery fast. Plus they dont cool very well on 12 volts. More then likely you have a 3 way fridge.
    Both of these assume you have a absorption fridge. In the unlikely event you have one that is 12 only, they speak true. But for at least a couple of decades the trucking industry has had available a 12 V compressor operated fridge I have heard some are making way to RV world.
    I never had 1, but friends did. One had to catch the bird home from Dallas, left his truck in a truckstop. By the time I got there to bring it home it had been sitting 4 days in Aug sun. I expected to need to jump start it because truck had same batteries as mine. When Cat started, I decided to do him another favor and MT the fridge. Opened the door, stole a ice-cream bar, and headed for home.
    I do not stand under why RVers want to store solar power as 12 V then waste some turning it into 120 to power the fridge.
  • We have a 2020 Coachmen Pursuit xps that has a 12 compressor refrigerator. No propane. Recommend some solar panels. The refrigerator is 12 cubic feet and works very well. We only camped in it once and had to run the generator for AC so I am not sure if the 200 watt solar panels can keep up.
  • Make and model of refer?
    I would say it is propane controlled by 12 volts DC!
  • Look for a controll panel on the fridge. It might be outside under the fridge vents. Or on the front. I've really never seen a fridge that was just 12 volts in a camper. As stated it will drin the battery fast. Plus they dont cool very well on 12 volts. More then likely you have a 3 way fridge.
  • question if its only 12v ?it would run a battery dead real quick. find a friend and have then do a walk threw on your rv,show you where things are and what they do,have fun.
