plasticmaster's avatar
Oct 30, 2017
12 volt ideas for exterior of camper???
Now that I've removed my electric stabilizer jacks from my camper, I need to cover the hole where the switch for the jacks were located. I thought about just covering it with some sort of trim plate, but then thought it would be a shame not to utilize the existing 12 volt power that's already run to this location. I thought about a 12 volt led light or possibly a cigarette power plug. Does anyone have other ideas? I want it to be functional and also completely cover the hole from where I removed the jack switch. If you have a link to go along with the idea, that would be great. Thanks.
  • You should have 2 holes. Likely on the side opposite the door. Not a real handy location for running most things.
    I would just leave the switches in place. Then when it is time to sell, you could easily put it back to stock for better resale.
  • As for Anderson Power Poles they come with a lock pin but no one uses them and then they blame the Power Pole plus they wont use Non conductive grease.
    http://www.ebay.com/itm/like/270408233483
